imported_Aslund
I had a discussion with a person. I must say that I know a bit about things inside a CPU, but he said things I had never heard about before and I would like your help to confirm if it is true.
First he said that the longer pipelines on Pentium4 are good because it helps on stalls in the CPU.
The reason for this is, that the longer pipelines on Pentium4 gives time to check and correct any problems on the way. Therefore has Pentium4 longer pipes, he says.
Also that there are a big difference on Athlon and Pentium4. He says that Athlon runs on a newer and smarter technology, and therefore can Athlon manage to have high performance on low speed.
He claims that he had seen a test of Pentium4, where it was mad to fail and then see if the pipes could solve the problem before the number of steps has run out.
Also that there is a very big difference on Prescott in socket 478 and socket 775, so much difference have I not seen.
Kind regards
Sebastian Aslund
Kind regards
Sebastian Aslund
