I am new to SCSI and SCSI RAID. However, I just got a PERC 3 (AMI Elite 1600) SCSI RAID card and 2 Seagate Cheetah ST318405LW's. I put them in my computer and they are working like a dream. However, I do not think that I am getting all I can get out of this setup. I ran a Winbench Disk Transfer test and I am getting a flat line basically at 52Mbps. Now of course this means a bottleneck since each of these drives have something like a 40Mbps beginning and a 25Mbps end transfer rate so I would expect a sloped line starting somewhere closer to 80Mbps and ending somewhere around 50Mbps. So I am wondering is it Winbench (I really doubt it) and if it is could you recommend a better set of benches to test my drives. Is it my settings on my card? I have it set at RAID 0, Write Thru, Cached I/O and I think 64K stripes. I will look into that a little later and modify this post. I have a 64Mb DIMM on board but no battery pack. First time I installed OS I did Write Back, Direct I/O and it had exactly the same result. Or could it be my setup in anyway. I have an Epox 8KTA3+ w/ 1.4GHz T-bird. Of course this means that I am running the card on a 33MHz, 32bit PCI slot even though it has a 66MHz, 64 bit PCI plug. I am running Windows 2000. I am including the link to my system specs so if you are able to extrapolate any other potential problems. Another thing that I noticed is somewhere in between the time I first installed Windows 2000 and when I ran all the updates on the Microsoft site, there is a slightly annoying pause on startup. It last for two seconds where I cannot open up the Start Button. Of course both of these I can live with because once my computer is on, then there are absolutely no problems. Also I can live with a 50Mbps tranfer rate 😀, however when I dropped $900 on this I would like as much out of it as possible. I appreciate any and all help.
System Specs
System Specs
