Hi guys,
My 1.6a overclocked well to 2.1 Ghz on Asus p4b266-c MB for a year and half. Couple weeks ago I bought a 160G WD drive, and
upgraded the bios to support large hard drive. However, after upgrading the overclock stops working. The system just hang there shortly after w2k boots up. First I thought it was my 300W power supply problem, so upgrade it to Antac 430w, however, the problem is still there. Antec 430w should be enough to handle two HDs, right? So I believe it is not the power supply problem, then it must be the Bios problem, correct? I observed that at 2.1 Ghz, the VCore could be 1.76v or 1.54v (large HD disabled), but no matter what votage it is, system keeps hanging. Does it really mean that the new Asus p4b266c Bios doesn't
support overclock? or any suggestions? Thanks in advance.
