mustard010
Ok, this is my first time, and I just built my rig almost 3 weeks ago. These are the specs:
Abit is7-G Mobo
512 DDR OCZ (1 Stick)
Intel Pentium 4 2.4GHz 800 FSB
Antec 430 Case w/ Power Supply
Ati 9800 Radeon Non Pro 128 DDR
SATA Raptor 10k RPM 36.7
Ok, my cooling, is yes, the Antec case(3 case fans) and the CPU heatsink w/ fan that comes with the Pentium 4
My question is, can I overclock this to over 3.0 GHz without hurting or damaging my CPU ?
This is the input on bios
Brand Name: Intel Pentium 4 2.4 GHz
Frequency: 2.40 GHz
Cache Size: 512 K
CPU Operating Speed 2400(200)
x - Ext. Clock (CPU/AGP/PCI) 200/66/33/ mHz
x - Estimated New CPU clock 2.40 Ghz
x - N/B Strap CPU AS By CPU
x - Dram Ratio (CPU😀ram) BY SPD
x - AGP Ratio (CPU:AGP😛CI) Auto
x - Fixed AGP/PCI Frequency 66/33 mHz
CPU Power Supply CPU Default
x - CPU Core Voltage 1.5250v
DDR Sdram voltage 2.6v
AGP Voltage 1.55v
The temps currently(Without ocIng) is:
CPU Team 55 C
System Temp 40 C
I have little, to know knowledge about overclocking, the only things I know is to tweak some things, but if someone can hold my hand and baby me, that would be great. Please, just tell me how to change these settings! and last question, how do I use the pumped up 800 FSB fully, or is it already functioning? THANKS ALOT!!
Abit is7-G Mobo
Frequency: 2.40 GHz
Cache Size: 512 K
AGP Voltage 1.55v
CPU Team 55 C
System Temp 40 C
