- Mar 28, 2009
- 4
- 0
- 0
After researching sites and speaking with friends, I decided to take the plunge and build my first computer.
I am trying to build the Anandtech Midrange Intel System:
Motherboard: GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
Video Card: EVGA 896-P3-1260-AR GeForce GTX 260 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
CPU: Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500
CPU Cooler: XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
PSU: PC Power & Cooling S75CF 750W EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below)
DVD Drive: LG 22X DVD±R DVD Burner Black SATA Model GH22NS30
RAM: OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500)
HD: Western Digital Caviar Black WD7501AALS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
Case: COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case
Issue: I've done something wrong or the PSU is borked.
All the pieces went together without significant problems during yesterday's build. Today I wired everything up and attempted to start the machine. Nothing happened. I clicked the PSU switch a few times Nothing. I disconnected all the power connections and tried starting up the PSU up alone. Not a sound. I reconnected all the power connections and tried again. Nothing.
I'm almost 100% sure that I'm missing something basic. I believe everything is plugged in correctly, I've taken the standard static precautions, and I've been careful when handling all the components. I read a few reviews that this PSU can come "dead in the box" but I thought I should come to the boards before I RMA it.
I do have a few older computers around the house, I'm hesitant about removing their power supplies and trying them on this project only because I already feel a bit out of my depth. I do not have any electronics testing equipment. The only electrical tool I own is electrical tape.
Specific questions:
Should the PSU's integrated fan start when powered up, even if the PSU isn't connected to anything?
If the PSU is functional and my MB and CPU connections are correct, shouldn't the MB's LED lights come on, even if nothing else does?
Thank you in advance.
Specific questions:
