I am having a bit of an issue. I have a q6600 G0 purchased a while back. From day one the temps using coretemp would have cores 0 and 1 at 10-12c higher than cores 2 and 3 at idle or at load. In fact at times the difference is even more than 10-12c.
When encoding videos using Handbrake and H.264? I can max out my 4 cores. With 2 hours of encoding my cores 0 and 1 are at 62 and 63, while my cores 2 and 3 are closer to 50 and 52 (OC?ed from stock to 3.4 GHz)
I originally thought it was my heatsink/fan (tunic tower). I lapped that as I figured it was much easier to lap that and less dangerous.
After lapping... same exact problem. I tried mounting the cooler 10 ways from sun-down... still like 10 to 12 c difference at idle and even at load. I tried regulating the mounting and decreasing pressure on one side, increasing it on the other but still nothing if worse. Tried applying less, more, one line, 2 lines of thermal paste.. still no difference.
I then purchased another cooler (ultra 120 extreme) and the EXACT same 10-12c difference between cores 0,1 and 2,3.
I am at odds... since at this point it HAS to be the CPU base. My question is how do you hold the CPU or protect it while its being lapped? Can I cover the "sensitive" side (the part that will be facing up towards me when I lap) with tape? How do I avoid getting dust/metal from the lapping process all over that? Do I still use wet/dry sanding?
For the life of me I have no idea as to how to check if my lapping process is correct after I am done... I still don't understand the "graph paper" test and using a razor blade on my CPU and trying to see light through it, shows me nothing.
I am at a point now that I am just willing to go out and buy another Q6600 G0.
Any suggestions?
thanks!
Any suggestions?
thanks!
