Help on first build!
Ben7el
Processor: Intel Core 2 Duo E6400
http://www.newegg.com/Product/Product.asp?Item=N82E16819115004
Motherboard: ASUS P5W DH DELUXE
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025
Video Card: SAPPHIRE 100150L Radeon X1900XTX 512MB
http://www.newegg.com/Product/Product.asp?Item=N82E16814102037
Memory: CORSAIR XMS2 2GB DDR2
http://www.newegg.com/Product/Product.asp?item=N82E16820145034
Hard Drive: Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM
http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
Case: Thermaltake VA8000BWS Black Aluminum/Steel ATX Full Tower
http://www.newegg.com/Product/Product.asp?Item=N82E16811133154
Power Supply: ENERMAX Liberty ELT500AWT ATX12V 500W 90V~265V (Auto Adjusted) UL, cUL, TUV, CB
http://www.newegg.com/Product/Product.asp?Item=N82E16817194003
Moniter: ViewSonic VX922 Black/Silver 19" 2ms LCD Monitor
http://www.newegg.com/Product/Product.asp?Item=N82E16824116375
CD/DVDPlayer/Burner: LG Black GSA-H10N
http://www.newegg.com/Product/Product.asp?Item=N82E16827136091
Floppy Drive: SAMSUNG Black 1.44MB 3.5" Internal Floppy Drive
http://www.newegg.com/Product/Product.asp?Item=N82E16821103203
Fan and Heatsink: Thermaltake Big Typhoon
http://www.newegg.com/Product/Product.asp?Item=N82E16835106061
Keyboard: Microsoft Wired ZG6-00006
http://www.newegg.com/Product/Product.asp?Item=N82E16823109164
Mouse: Logitech MX518
http://www.newegg.com/Product/Product.asp?Item=N82E16826104178
Look good?
ta8689
1,116
Seriosuly.. get a bigger monitor. I wish I would have saved up a little mroe and bought a 21 or 24 inch or something.
Blain
Ben7el,
Now that you have joined the AnandTech forums, please take some time to actually read the dozens and dozens of threads EXACTLY LIKE YOURS.
Is there some reason you must have people come to your thread and tell you every little thing to purchase, or can you simply read the tons of recommendations already made in the other threads?
Redundancy should only be used in RAID 1. :p
BTW, You have told us absolutely nothing about how your "first build" would be used.
imported_mike77
7
I don't like anw lights in the case. Some first days looking good, but after some week this lights boring me. So case MUST HAVE feature to turns off the lights.
Skott
5,730
Well, I'm not going to get into things about how it 'looks' because beauty is in the eye of the beholder. Component match up wise it all works fine. You are going to find alot of people using the exact same proc, ram, and mobo combo as yours so sit down, grab a snack, and a drink, and read. Three good forums to view is, Anandtech, HardForum, and XremeSytstems. XtremeSystems has two very good threads about this mobo that many consider a must read. They a re also very very long threads. Anandtech has a official P5W DH thread as well in the mobo section. I suggest you read it as well. HardForum is another site I like that has alot of info as well. Seriously, take alot of time and read because you have a very common setup and its talked about alot if you look in the right places. You need to devote alot of attention to the threads if you intend to overclock. Alot of problems have been presolved by those that came before you. Good luck. You got a fine setup planned there.
hurtstotalktoyou
2,055
9
It looks very overpriced. I'd make a lot of changes. A lot.
1) The RAM is overkill. You can get a nice pair of 1GB DIMMs for $180 or less. Newegg has a Patriot kit for that price which looks very nice.
2) The motherboard is overpriced and out of stock. The ASUS P5B, at about $160 shipped, is over $100 cheaper, and should serve you just as well. I bet you could get something more than adequate for under $100 if you looked.
3) The monitor, too, is badly overpriced. Newegg has a great Acer 19-incher for under $180.
4) I suggest you get a cheaper case. $50 can get you something pretty cool. I wouldn't spend a penny more than $75 on a component that contributes nothing to performance.
5) I'd ditch the Zalman cooler. If you find the retail hsf inadequate, you can always upgrade later. And if you're spending that much, you might as well go for liquid.
6) The E6300 is less expensive and probably hits the same oc wall as the E6400.
7) Are you sure you need that caliber video card? You're spending more there than on your CPU. That doesn't strike me as balanced.
8) Are you sure $45 for a mouse is a wise purchase? Mine cost $6. Also, you could save a few bucks by getting a generic keyboard.
9) For $5 more, you could get a Samsung DVD burner with lightscribe, without giving up any real-world performance.
Hope that helps.
StevenNevets
915
He has 2 posts....
The case is overpriced
he psu will probobly do the job but I'd suggest something
Power Supply: OCZ GameXStream OCZ600GXSSLI ATX12V 600W Power Supply 100 - 240V CB/CE/CSA/UL/FCC http://www.newegg.com/Product/Product.asp?Item=N82E16817341001
($119.99 after $10.00 Mail-In Rebate)
This is another option incase you'd rather not have 4 extra, useless buttons on a mouse
Mouse: Razer Krait 1600 DPI Gaming Mouse
http://cgi.ebay.com/RAZER-KRAIT-1600dpi...categoryZ23156QQtcZphotoQQcmdZViewItem
People always say Seagate is faster somehow
Hard Drive: Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM http://www.newegg.com/Product/Product.asp?Item=N82E16822148144
$79.99
This monitor costs the same as that one but is bigger... and still of nice quality
Monitor: BenQ FP202W Black 20.1" 8ms Widescreen LCD Monitor 300 cd/m2 600:1 0.258mm Pixel Pitch
http://www.newegg.com/Product/Product.asp?Item=N82E16824014105
($259.99 after $30.00 Mail-In Rebate)
If you're going to overclock get this RAM here - can easily match that ram for way less
Ram: Patriot 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 667 (PC2 5300) Dual Channel Kit System Memory http://www.newegg.com/Product/Product.asp?item=N82E16820220095
$179.99
acegazda
2,689
Hope that helps.
Get OCZ gold 2x1gb ddr2-667 for $140 AR @ newegg. The gigabyte 965p s3 is a good choice for a MoBo for $118 @ ewiz. A good hsf is the arctic cooling freezer 7 pro. It is available @ provantage for $21 shipped. BTW if you wan't the x1900xtx, it is available from ZZF for $277 after $150 MIR. It's a big rebate, but worth it if you don't mind waiting. If you want an all alumium case get the lian li pc7b +2 for $90 @ newegg shipped. For the psu, get the enhance 5150gh, it is the superior value and in september, they are releasing a version 3 with 36 amps combined on the 12v rails. It is 80+ certified as well for $80 shipped from ZZF.
DerelictDev
358
I just ordered my new build and it is similar to yours aside a few changes.
I think you should ditch the RAM, MB, & GPU.
I agree with hurtstotalk, the ram is overkill and you could get yourself a much cheaper 2gb kit.
Your planning on getting a E6400 (So did I) so why bother spending all that extra money on an Asus MB? Get the gigabyte DS3 and save $$$ plus from what I've read, alot of members here seem to get better results in O/C using the DS3 & 6400, if you were to go 6600 then yea, I would say stick with Asus.
The video card is a great choice (I got the same thing) but don't get sapphire, the MSI x1900xtx comes with a $150 mail in rebate which is a killer deal. http://www.newegg.com/Product/Product.asp?Item=N82E16814127205 Comes out to only $280 after rebate.
As for the monitor, that was one of my first choices but switched and bought the Samsung 940BX after some advice I got from the boards. The monitor came out just recently so theres basically no reviews but for $275 @ 5ms + Samsungs good reputation for most of their lcd monitors, I took the risk.
Blain
He has 2 posts....
That's very apparent. :roll: The "other threads" remark was referring to...
...Next
hurtstotalktoyou
2,055
9
Hope that helps.
All good, except I wouldn't buy anything from ewiz, as they have an unsatisfactory record at the better business bureau.
StevenNevets
915
He has 2 posts....
...Next
whatever, take a guess what this forum is for
Ben7el
Hehheh, sorry, I made this thread at 2AM so I was sorta tired
I want this comp for gaming, I don't need to have every game I play for the next 4 years be at Ultra high settings, but I also want to at least keep some grapic quality. Also, I don't want to do a major upgrade on this comp in the next 4-5s, maybe get a Directx10 Video Card but thats it.
I have also read alot of threads, most of which are sort of helpful, but I havn't seen anyone with my exact build so I want to make sure it doesn't work for some reason.
acegazda
2,689
Ewiz has great ratings (see resellerratings.com) in all aspects except RMAs... so basically If the stuff does what it's supposed to, you're golden. Anywhere else to buy a e6300 and gigabyte 965p s3 for $305?
jmagg
2,313
500
He has 2 posts....
...Next
And redundant posts like yours.
Hidden Hippo
183
I'd say the rig is all good. The only thing I'd change is the graphics card. I'd get an x1900xt instead of an xtx. The price difference just isn't worth the tiny speed increase. Just beware when mounting the PSU, it is a little awkward to get into the hole as it must be mounted sideways.
