jlee
Originally posted by: DingDingDao
Originally posted by: FrankyJunior
Easiest thing to do is not worry about timing. Just let off the clutch and floor the gas at the same time. You'll get going in no time.
Okay, then how about this?
OP, just floor it and let the revs bounce off the limiter, and then drop the clutch and get ready for:
a) tire squeal galore
b) need for new tires very soon
c) need for new clutch very soon
d) all of the above
I'll let you guess the answer.
e) new transmission
The clutch will probably be fine..unless it was crappy to begin with. 😛
