Help on deciding between 2 2.4c's for OC.
iTsOn
Hi, I have a choice of either P4 2.4c to use. I want to get a 1:1 overclock, nothing big or record setting. I want to try to keep stock voltage and use Zalman 7000alcu. At best I'm hoping for 250FSB so 3gigahertz. Thank you in advance!
Chip #1
Prod: BX80532PR2400DSL6Z3
BATCH#3334A090
PACKED: 11/26/03
listed as "1.525V max"
Chip #2
Prod: BX80532PG2400DSL6WF
batch: Q320A350
PACKED: 06/17/03
listed as 1.525V max
-Will
Both should do 3.0Ghz/250fsb on default no problems. As long as you use a good overclocking motherboard such as an Abit or Asus.
I've actcually have had both and still use my SL6Z3 2.4 at 3.4 on default vcore. Use it 24/7 completely prime95 stable with 2 instances (for HyperThreading) and everything else like gaming, and all my work apps I throw at it.
