help on choice a case!!gigabyte 3d auroa or coolermaster haf 932
yingyan
just got intel sandy bridge cpu
plus all other parts
decide on the case
i have a gigabyte 3d gigabyte 3d aurora case
link:
http://www.newegg.com/Product/Produc...82E16811233002
should i still use this case or should i go:
cooler master haf 932 case
http://www.newegg.com/Product/Produc...-160-_-Product
the reason i ask is gigabyte case is about 4 years old it is Aluminum ,only thing i think is power supply is on top,all the new case the power supply is on the bottom is that matters?
i like the haf case but it is not Aluminum
which should i go?
thanks!!
It looks like the only things the Aurora case has in its favor is that (1) you already have it...thus saving quite a bit of money, and (2) it's made of aluminum, so it's pretty light if you need to move it.
I'm a fan of the HAF cases. I bought one for my new build.
If you need more convincing...look at some of the fine work in this thread:
http://forums.anandtech.com/showthread.php?t=2125015
thanks !!
the reason i ask is my friend will trade his haf for my gigabyte case
i think i will trade with him then
Another benefit (IMO) to the HAF 932 is the width. Gives you an extra inch (or more w/o mobo tray) for large coolers.
