***HELP ON BUYING GRAPHIC CARD 8800GTS***
solidsnizzle
4
Well Ill have to say I'm not a very rich kid and based on my last computer purchase (6yrs) ago buying a good build and worth the money stands the test of time pretty good for about (6yrs) lol.
But yea here ill lay it down, Ive been thinking about buying a 8800GTS 320MB. Mainly becuase Im in no position to buy a 600$ GTX, and from past experiences i was looking forward to a card that can outlast for a while since im not buying another computer for 5 to 6 more years, and to me a 300$ DX 10 is the sweet spot in my opinion. (please if you consider anything I am buying a rip off ENLIGHTEN ME !! PLEASE !!)
Infact I am making this purchase near december so ill have time to revise and find better deals so time is not a problem.
Here is my planned build
CPU=Core 2 Duo 2.33 GHZ (E6550)=170$
RAM=Crucial Ballistix 2GB 240-pin (2x1GB) =110$
GPU=nVidia 8800GTS 230MB=300$
Mother=ASUS P5K=215 $ (I intend on changin the motherboard for a cheaper one)
POWER= ThermalTake 430W =40$
This is my build i created from items offa newgg.com Its a very rough build with some time put into it but i will definetly change it if needed too.
Please i really understand the market and how they give big numbers or popular brands higher prices than valued to create a illusion for consumers to buy... I really want to save as much money as i can. So it would be tremendous help for diffrent prices found and better hardware.
Overall my build right now is at 1.4K with everything included TAX+s&H so its pretty good so far i plan on dropping it to 1.2k if i can
Any suggestions or information would help !!!!!
one last thing ....should i scrap this whole custom built and go the way of pre built at stores like best buy ??
Capitalizt
Banned
Nov 28, 2004
1,513
ok buddy I think I can help. First, I saved you $2 on the processor ;)
Link:
http://www.zipzoomfly.com/jsp/...p?ProductCode=10005520
For the video card, I highly recommend you pick a quality brand like EVGA or XFX. They back up their products with a lifetime warranty and have great customer support.
Here is a good price for your 8800:
http://www.zipzoomfly.com/jsp/...&prodlist=pricegrabber
And a motherboard that should overclock very well:
http://www.newegg.com/Product/...s&Item=N82E16813128059
Also, that power supply definitely will not be enough to handle everything in your rig. You should go for a high quality 500 watt...don't skimp! (unless you like random reboots).
This one is rock solid. $89.99 shipped when you pay with google checkout (takes 30 seconds to register)
http://www.buy.com/prod/corsai...loc/101/203270716.html
Here is one of the best CPU coolers...very important if you plan on overclocking:
http://www.ewiz.com/detail.php?name=FAN-AC7PRO
Case fans...You'll need a few of these to keep things cool. Make sure to have an intake AND an exhaust! :)
http://yesbuy.net/yateloon-120...2-3pin-4pin-black.html
For your RAM, get this...it's just plain awesome. It's $90 on newegg...5 star reviews. Only $54 after rebate here:
http://www.clubit.com/product_...343475&cmp=AFC-CJ_CBIT
That should get you started.
edit: Some of these are SALE prices and won't last long...so get what you can now (at least the case fans, lol;))
