- Sep 2, 2004
- 14
- 0
- 61
1. What YOUR PC will be used for.
Basic stuff and a lot of Gaming, but most of the games I play are not graphics intensive (ie- warcraft 3, civ4, WoW, etc...)
2. What YOUR budget is.
About $1000 for the base cpu (don't need to buy a monitor, keyboard, etc.).
3. What country YOU will be buying YOUR parts from.
USA. But i plan to take it to India as I am moving back
4. IF YOU have a brand preference.
None, except that i'm sold on intel due to their performance atm.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Yes, my 20" samsung 205B, logitech G15 keyboard, G7 mouse, audigy2 ZS platinum soundcard, couple of 250 GB hard drives.
6. IF YOU have searched and/or read similar threads.
Yes, i have read some of the other threads and pretty much all the recent guides on anandtech and tom's hardware.
7. IF YOU plan on overclocking or run the system at default speeds.
I dont plan to overclock, but have picked my parts such that i could.
Most of the parts are the standards from the guides I've seen out there. Mostly, I'm just posting this to confirm that the parts are good and would last me 2-3 years and give me good performance even then. My last cpu was a p4 about 4 years ago, and i got killed on the upgrading because the motherboard was AGP and so it really hurt my choices. I don't want to have that same problem again. Also, most of the guides are a few months old so they may not be good choices as of now, April 08.
CPU:-
Intel Q6600.
What cores/FSB speeds should i be looking for, or is there only one type of Q6600 out there?
MOBO:-
Abit ip35 Pro
MEM:-
Crucial Ballistix 2x2GB ddr2-800
Should i go for ddr2-1066 or other memory keeping in mind i want this to last for 2-3 years.
Video Card:-
I already bought the eVGA 8800GTX so theres no choice here. (was a good deal on it)
Case:-
Antec 900.
I like the spaciousness of this case and the cooling. Since this case is gonna be in India, and its hot as hell there, and i like leaving my PC on, i figure i need it. Plus its solid and i can take it to India without worries of it breaking on me during the travel.
PSU:-
No idea here. I was thinking about the 750W pc power and cooling since thats got good reviews.
Other
Any recommendations on heat sinks for GPU/CPU. I have heard good things about zalman and thermaltake.
Also, I was wondering if having one raptor to install my Os/critical programs on would help at all, or maybe a 16GB solid state drive?
edit: Noise isnt really an issue for me, as far as cases, psus and heatsinks go...
I pretty much have most of the other stuff. Thanks in advance for the help
CPU:-
Intel Q6600.
MOBO:-
Abit ip35 Pro
MEM:-
Video Card:-
Case:-
Antec 900.
PSU:-
Other
