Hello all. I'm new to the forums, but not to Anandtech.
I have years of experience building PCs, but none building any type of server. I need to build a server for an nonprofit organization and would like any suggestions from the community. This server would mainly be running apache, hosting a 2000 user message board and some static web data, SMTP and POP daemons, a shoutcast server and finally an IRCD.
The budget is around $1000, but we'd like to keep it well below that number.
The server will need to run 24/7 with minimal downtime of course. It will be housed at a colocation datacenter. I'm definatly going to run a flavor of UNIX, still not sure if I want to go with FreeBSD or linux, but I'm leaning heavily towards SuSe linux. I do have a bias for AMD, so unless its of great advantage, Intel is out.
My real problem is what rack case to get. I really have no clue what manufacturers are good in this area and would like suggestions.
Second, in the 2U space, what mobos are avilable to me? Will a regular miniATX mobo work? Does it depend on the rack case? Are there low profile concerns I need to take into consideration? I don't want to get a mobo and find out it doesn't fit.
As far as the rest of the hardware goes, I'm pretty confident I can choose and install it (its the same hardware as PCs after all.) But if anyone has any suggestions on what mobos, RAM and HDDs are good for a server enviornment, by all means please suggest away.
The basic hardware I'm considering is:
AMD 939 based Athlon 64 (possibly a 940 Opteron) and appropriate motherboard
2x 512 MB RAM (possibly 2x 1 GB RAM if the budget allows)
2x 120+ GB SATA HDD
Thanks in advance.
2x 120+ GB SATA HDD
Thanks in advance.
