Help on Asrock 780g memory setting
rubberneck
150
I have the Asrock 780gmh/128 with Regor 240, clocked at 245x14 (3430). I have 2x1GB HyperX DDR2 1066 which I have set in bios to 533/1066. The issue is that it shows up as 245MHzx2 in SANDRA, CPUID and AMD overdrive. Any insight on what's going on here?
Thank you.
rubberneck
150
Okay, it seems the setting "flexibility option" which is supposed to help with memory stability does so by running the FSB to DRAM at 1:1. Disabled it and now it's at 1:2 and my memory speed is double which the SANDRA memory benchmark seems to validate!
