- Jan 23, 2002
- 2,119
- 0
- 0
I'm puting together my first computer and have a Seagate 80GB HD. I downloaded a fresh/full version of Windows 98 for PC's without windows last night but went out today and bought the XP upgrade disc.
I wanted to do a "clean" install of the XP software. So I did a format from the dos prompt to the C: drive (which is the Seagate HD). While installing the XP software I was prompted as to which area to format or delete I saw a FAT32 partition on there from Windows 98 (wanted to keep all my files NTFS) so I highlighted it and deleted it and proceeded to do the format.
However after my fresh install of Windows XP my HD is only showing 74GB of free space. Does Windows XP take up the extra 6GB? I think not. The FAT32 was the same size as the missing 6GB.
What do I do to do a "Full" format and start as if I just put a new drive in?
I tried to do a format C: from a bootable DOS floppy disc. But drive C: is not recognized?
edit: I was hoping to be able to report back if the "low format", "zero fill" & then a clean install of the Windows XP worked but that zero fill takes a loooooooooooooooooooooooooonnnnnnnnnnnnnnnnnnnnngggggggggg time! It's been about 1/2 hour since I started it & I'm @ 6% :disgust:
Thanks.
Thanks.
