Hi, all-
It's been a while since I last built a PC and things have changed past recognition so looking for any and all help.
Purpose: Work (primarily MS Office, but does get heavy so memory and processor intensive at times) and play (computer games) build.
Budget: $1000-$2000 w/o monitor but would go over if necessary - but don't want to if don't have to.
Things that matter: quality case. Intel processor (sorry, had a couple of bad experiences w/AMD and am scarred), case appearance (going for classy vs. flashy - sleek is better, quiet is better. If can do something that's not huge - even better), would need an optical drive (and so prefer BD reader / recorder combo).
Resolution to drive: Looking at an ultrawide mostly for work so would be nice to drive the entire 3440 x 1440 for games. If not - then still XXXX x 1440 to stay native.
Need help deciding on:
Processor (Intel) - would prefer to run non-overclocked - just to much PITA for me nowadays
Heatsink - thinking of Noctua NH-D15 - want to stay away from liquid. Again - just too much PITA and big downside
Mobo (it seems nowadays it's easy to spend major $$ on these, but is it necessary?!)
Memory (quantity - 16 GB?! - AND brand / type / timing)
Case - again, sleep is better. For instance, HP since to pack a lot into something like the ENVY 750 tower, including a GeForce 1070 - but are there similar enclosures available to DIY'ers?! Can't seem to find any. Would go up to the typical mid-tower. Used to be partial to Lian Lis for reasons of weight (Aluminum - good), understated looks, and thermals, but they are pricey and also seem to be on the larger end of the spectrum. Anything cool / new around?
For HDDs I'd go combo about 512Gb +- SDD with at least a TB HDD for large storage
Gfx - thinking of GF 1080 to drive it - would prefer to stay single card - not a fan of multi-card setups plus those are expensive and the 1080 seems to be able to drive the resolution OK
Decent power supply to drive it all
I think this covers it. Appreciate any input.
