MajorPayne
I have one of the new Chaintech VNF4 Ultra motherboards, running an A64 3000+ winchester core. I have been able to get it to clock up to 240 HTT in BIOS (where others have reported being unable to pass 220 with this board) running the processor at 1.5 V, (where it runs at 21-26 degrees C depending on the load, so I know I have room to go further!) and the memory (2x 512 of Kingston hyperX 3200) at 1.7V. I had to lower the HTT multi to 4x (from 5x) to get it to OC, but this is expected. I also set the RAM speed to 166 (down from 200 by default), which at a 240 HTT makes the ram speed 406 MHZ.
The system is VERY stable at this overclock (runs at 2.16 GHZ up from 1.8 stock), but I KNOW it can be pushed further than this. Every OC I try above 240 results in the motherboard rebooting to "safe settings" where the CPU is clocked down until I go into BIOS and set the OC back. I have tried lowering the HTT multi to 3 AND then to 2, and I dropped RAM speed to 133 and relaxed the timings a LOT, but still cannot get one whit past the 240 mark. I suspect that my CPU voltage needs to go higher, in order to get a better OC. I have tried upping the RAM to 1.8V, but I still could not get any higher.
Which brings us to my questions. For those who have overclocked an A64 3000+ winchester (or any other winchester), did you need to raise your CPU voltage past 1.5, and if so, how far up did you/can you safely go? Any advice or examples from a working overclock would be appreciated. Ordinarily I would just run the sucker up, but I used up all of my wife's "goodwill towards technology upgrades" just getting her to let me buy the new processor, motherboard, and graphics card (a 6600GT). If I fry this processor, I will be without a new one until I can weasel yet more upgrades out of her!
By the way, I MAY have cool-n-quiet enabled (I think I do, because I think it is defaulted to ON on this board), and I have heard that this can limit your overclocking ability as well. Any thoughts on this too?
