- Feb 7, 2002
- 188
- 0
- 0
I am having a problem with this program hijacking my image file associations. It happens when downloading image files from a news server. 99% of the time the image files will open in an Explorer window (default setting) but every once in a while an image will cause the
Photosuite program to open up which changes all my image file associations. I assume these particular images were edited and saved using the Photosuite program. I have tried uninstalling this program but when I do it screws up the Image preview feature in Windows Explorer. Luckily I have SecondChance installed on my computer which restores everything to the way it was prior to the uninstall.
Any Ideas on how to disable this program or how to restore the image preview feature after uninstalling it? Would removing the Photosuite exe file from the photosuite folder keep this bastard program from launching? I am using Win98SE.
Thanks for any ideas
