HELP: NTI CD Maker Pro 2K won't start
QTPie
1,813
I installed NTI CD Maker Pro 5.1.9 (latest) in WINXP. When I opened it an error window poped up that said:
Cdmkr32.exe - Unable To Locate Component
This application has failed to start because WmaCodec.dll was not found. Re-intalling the application may fix this problem.
I reinstalled it couple times already, but still nothing.
Any suggestion?
emjem
1,516
Did you try uninstalling it before you reinstalled it? Also, make sure you don't have any other burner software on your system when installing it.
