So I've got a conundrum of sorts. I have a loop consisting of two 290x and a 4790k with 2 Alphacool Monstas (3 fan 120x80) and a swiftech MCR320. using EK copper blocks on the 290x and the new Apogee XL with a custom biohazard plate from performancePCs, and the best temps my CPU will do are whatever my GPU load temps are. The cpu is down loop from both GPUs and is getting cooled by water which has just past through both cards, so i'm limited in how cool i can get the CPU because of this. I know that normally in a water cooling loop, the water reaches a steady temperature after operating at load for an extended period, but when it's a hot day out this means that my CPU is idling at 60c.
I havent gone to overclock it yet because I need to make some other modifications to the loop anyway, and I was wondering if anyone had ideas for what would be best to keep this beast of a loop cool? I have an extra black ice extreme GT2 I could put in the loop after the GPUs but before the CPU possibly since I havent put a radiator in the top of my case yet, everything else is compartmentalized into HAF Stacker 915 units. I have a D5 pump with dual outputs so adding another radiator and running the CPU + that radiator would be easy without adding my second D5 to the loop as well, but there's plenty of space in my case and I have another reservoir as well so it wouldn't be an issue, but my knowledge of watercooling tells me the only way to get that CPUs idle/load temp decoupled from how hot my GPUs are running is to run separate loops. Anyone more pro than me want to chime in?
Photos bellow for those trying to imagine how it's all set up. I was hoping not to put a radiator in the top so i could put an all air cooled unit on top and have it safe from any leaks that may happen in the future, but now that I've figured out which of my two old radiators was the one leaking (pictured running with the red fans, why I'm rebuilding, the MCR320 is going in its place), I'm more concerned with the top system's total performance and can stack that ITX backup in underneath the beast. Also, currently one of the Monsta radiators is venting inside the (middle) case, i'm switching the entire radiator stack to full exhaust so i'm not venting hot air into another radiator or inside the case since my PSU's also sucking up heat and running at near the radiator's exhaust temps. Im also using a 10% glycerin coolant i mixed myself this round because in the past i used a pink PG based dye and it gunked up two of my other radiators, and it's worked nicely to dissolve all the left over crap along with the hot water, so I need to empty it ASAP to rinse everything and reloop it again with emerald green tubing to match the secondary reservoir.
http://imgur.com/F47tkbx
