Hi Guys,
we are trying to build a PC and we are getting the error:
CPU is unworkable or has changed. Please recheck.
Using AMD 1800+ and Abit Nforce Mobo. I searched for the error on the internet and found the stuff below, but the problem is we are too noobish to know what we need to do. I.e. where is the soft menu, or how do you load bios settings? We need grandmother directions please. Thanks
"The problem is that Abit (by reasons unknown to us) has included an option in their Soft Menu called "Speed Error Hold". This option halts the system, if the speed is not set at default. This means that if you intent to overclock your CPU, you should disable this option. In short, set "Speed Error Hold" to "Disabled" and it should work.
this evening i get the same problem with my abit mainboard without change any speed settings,
BIOS settings or CPU. Here my easy solution: load the BIOS defaults or optimized defaults,
change your values and save the settings. Now the message doesn't show."
