Help - no video w/ 1155 build on Asrock Extreme3
swilli89
1,558
1,181
Ok so everything is assembled and it powers on first try.
Problem is, I am getting no video!
Motherboard is giving me a code of A3 on the diagnostic thing on the board itself.
The manual tells me this is "IDE Enable"?
Just a check list so far:
I've tried both DVI ports on my Radeon 4890 as well as the integrated DVI port on the motherboard itself.
Both main and 8-pin power cables are plugged into mobo and video card also has both its 6-pin power cables plugged up.
The usb keyboard and mouse are plugged into the top 2 usb 2.0 ports up by the traditional ps/2 ports.
Anyone have any ideas?
Edit: Cleared Cmos and is working fine now.
