Help - New Case. PS Doesn't power on...
exorr
I just purchaed two In Win V523T cases with 300W Power Supplies in them. Nice little case, installed all pieces easily and without issue, but when I go to turn it on, the PS doesn't seem to get any power.
I plug the power cable into the PS and the fan in the PS doesn't turn on. Yes, I'm flicked the power switch up and down. I'm even tried changing it between 115V and 230V via the switch on the outside of the PS. Nothing. This is happening on both cases. Now, I want to find it hard to believe that I got two cases with bad PS's so I'm hoping there's something I'm missing.
Can someone help? 🙂
Thanks,
Ethan
Do you have a p4? If so, make sure the separate 4 pin connector is plugged in as well. I've forgotten to do that a couple of times myself. Alternatively, you may have a bad PSU or it may be incompatible with the particular model of motherboard.
Ignore my last post, I'm a chano...
I figured it out...I had the "On/Off" jumpers plugged into the wrong areas on the mobo. I moved them each 1 to the right and it booted.
I knew it was something stupid like that...I didn't realize the system wouldn't even get power if I did that...🙂
