thedoormat
Hello everyone,
I'm evaluating building my first ever desktop and need some help deciding what components to buy, if I am forgetting to consider certain elements and general suggestions that I might not be considering.
1. What YOUR PC will be used for.
Light gaming, Photo editing, Engineering 3D Softwares (Solidworks) and some minor FEA
2. What YOUR budget is.
$1,000 (OS not included)
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference.
Intel, only because I am slightly more familiar with them at the moment.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Keyboard and mouse?!
7. IF YOU plan on overclocking or run the system at default speeds.
Not planning on overclocking. But on reading the sticky by mrSHEiK124, reconsidering that stance.
8. What resolution will you be using?
1920x1080
9. WHEN do you plan to build it?
Between July and September 2012. Willing to wait a little more if the price is right.
Here is a list of components I have sort of settled on.
CPU: Intel i5 2500K. I picked this instead of the 2500 because they differ only by $10.
Question: Is it true that the 2500K is primarily for overclocking? I looked at the benchmarks and cost to decide on the 2500K.
Motherboard:
ASUS P8Z68-V/GEN3 approx $160
OR
ASUS P8Z68-V LX approx $120
Question: I am going to be using 1 SSD, 1 Hard drive (for data), 2 DVD Burners (1 to be salvaged from a defunct work computer), 4-5 USB devices excluding mouse and keyboard. Are either of these overkill? Are both of these overkill?
Question 2: I noticed that both MBs have 2xCase fans. Does that mean that the 3rd fan in my case will be useless?
RAM:
4x4gb G Skill Ripjaw PC3 12800 $95
Question: What is the difference between the Ripjaw and the Ripjaw X? They are priced the same on newegg.com
Hard-drive:
90gb OCZ Agility 3 SSD ($55) Buying this as I type this.
Seagate Barracuda ST1000DM003 $95
Question: Since the SSD is going to be the primary drive, can I afford to go with a slower drive for my data drive? i.e. SATA 3GB/s vs 6?
GPU:
XFX 695x Radeon 6950 CDFC $230
Question: What is the difference between CDFC and CNFC?
Question2: Again, relying on benchmarks to make this decision. Are there any other GPUs I should be considering in this price range? I would like to try to save some money on the GPU if the performance isn't drastically reduced.
Monitor:
Asus VH238H $160
Open to other brands etc. Min 22" I suppose. I have a 21.x" at work, and it seems to be fine for what I need. Just a decent resolution (work computer is at 1680x1050 which I sometimes find lacking).
Case:
Rosewill CHALLENGER U3 Black Gaming ATX Mid Tower $60 ($40 AR)
Question: Should I be thinking of saving money on this by getting a smaller tower? Or at this price point ($20 rebate currently on this tower), will the larger case allow for better circulation? I prefer a minimalist tower.
Fans:
The case comes with 3 fans (2x120mm and 1x140mm). Do I still need to get a fan? If so, which one would you recommend?
DVD Burner: $15-20
PSU: I am thinking about a 600-650 W PSU for this build. Will that be enough? If yes, I am considering the OCZ ModXStream Pro 600W. Is that a good buy? Any recommendations?
Not sure if I have missed anything out, but I am sure that if I have, someone will point it out. I have tried to make it as specific as I can, so there is very little confusion from this.
USA
1920x1080
Motherboard:
OR
RAM:
Hard-drive:
GPU:
Monitor:
Asus VH238H $160
Case:
Fans:
DVD Burner: $15-20
