Help Needed:Problems getting NVRotate working(nvidia lcd rotation)
ss284
I have version 52.16 drivers(downloaded from nvidia.com) installed on a geforce 1 sdr card, and I want to rotate my display 90 degrees to the right so i can view my lcd in landscape mode. I know that NVRotate has been a part of the nvidia drivers since the detonator 40 series, but for some reason the damned menu refuses to show in the nvidia advanced configuration. Ive scoured the menus, and couldnt find it. I've even tried setting hotkeys, but the display refuses to rotate.
Is there a special regkey i need to change to get this menu? Ive uninstalled and reinstalled the driver to no avail.
Btw, im using windows xp.
Thanks,
Steve
I have nview enabled, it doesnt make a difference. NVrotate should work on whatever nvidia card its used on, as its just a simple resolution/orientation change.
-Steve
panel
Yours should be similar with nvrotate listed.
Couldn't you also try an older driver. Since I doubt the newer driver has any improvements for the older cards.
