Baasha
I have decided to get a dedicated NAS system for my rig. I already have a "network" drive (one external HDD) for backups and that serves its purpose quite well.
However, what I am looking for is as follows. I want to get an external RAID enclosure (RAID-0 or RAID-10) mainly for video editing.
I need this "server" to be able to store large video files, pre-render and post-render, and also capture video from games (using FRAPS etc.) fast enough for there not be any stutter and/or lag. I also want the drives to be fast enough to be used as scratch disks for Photoshop, Premier Pro, and After Effects (CS5).
I also do a bit of Cinema 4D so I would really like to have a dedicated NAS system to be able to store, playback, and capture media content with ease.
Which NAS systems do you guys recommend?
I am looking at sub-$1k systems so no SAS racks etc. I may consider exceptional systems that are a touch over $1k (~$1100 - 1200).
Ideally, I want a minimum of 4 drives (4-drive bay) with 1TB HDDs (7200 with a minimum of 32MB cache). Although, I've heard the WD Caviar Blacks have a 64MB cache! If I go to higher number of drives, say 8, is that too much overkill? I don't see myself needing much more 5TB for a while so I'm not looking for 10TB+. I wouldn't mind getting a 8-drive bay system though and perhaps expand later by adding more HDDs.
The other thing I need to mention is that I am going to be connecting this NAS system via eSATA (on my motherboard; the ASUS P6T7 WS SuperComputer). Since my motherboard is not USB 3.0 compatible, I figured eSATA is the next best bet. Firstly, if I connect a 4 or 5 drive NAS system to a single eSATA connection, will the internal RAID sysytem of the NAS device work properly? I read somewhere about eSATA port multipliers or something and I'm not sure what that is or whether I'd need that for my system to work optimally.
I would most likely be going with 4TB RAID-0 to get the maximum read/write speeds. This NAS system will be used for video editing stuff about 90% of the time. The rest will be for backups of important files for redundancy. I already have another external HDD for backups but the space on that drive is shrinking by the day.
Some of the NAS systems I've looked at so far are below. Any suggestions regarding these are welcome. I am looking for the best performance; aesthetics of the NAS system is a distant second priority.
Thanks in advance.
- LaCie 5big Network 2 (5TB) - http://www.lacie.com/products/product.htm?id=10485 - $899
- LaCie 2big Quadra (4TB) - http://www.lacie.com/products/product.htm?id=10310 - $499
- LaCie 4big Quadra (4TB) - http://www.lacie.com/products/product.htm?id=10313 - $799
- LaCie 2big Network 2 (4TB) - http://www.lacie.com/products/product.htm?id=10477 - $449
- Synology DS-1511+ - http://www.synology.com/us/products/DS1511+/index.php - $924.99 (DISKLESS) actual cost will be well over $1000 with 5 1TB Caviar Blacks!
Thanks in advance.
