Hey guys, having some rather serious probs on a mates computer.
Specs:
Athlon 3800+ Venice core
DFI SLI-D mobo (not sure which BIOS, the one it came with.)
XFX 6800GS PCI-e version
Kingstion Hyper X Dual channel (2X512) PC3200
Seagate Barracuda 80 gig SATA drive
ASUS DVD drive
Logitech G15 keyboard
Razer Copperhead
After turning on for the first time, XP booted as expected, detected the mouse and keyboard, and then asked to restart.
We then installed the Razer software, then the Logitech software (no reboot after either). Then, using a USB flash drive, installed Winzip 10, and Everest at this point, while attempting to extract CPU-Z 1.32 (from a winzip file) from the flash drive, the system froze, and so we restarted.
This is where the problem kicked in. The display was ok, but "fuzzy", with horizontal grey lines over the whole screen. For the entire boot process the display is odd, and booting into normal mode, the display simply stops. Booting into safe mode, the display is still having issues, but worked. We attempted to restore to the a restore point but, the mouse is non functional, and so is the keyboard.
So, any ideas? no screenies unfortunately.
Specs:
ASUS DVD drive
Razer Copperhead
