Hi, I have a Athlon64 3500+ (New Castle core),
My main question is, when I set the cpu values at 95% of my maximum speed to attempt 12hour prime stability, do I have to keep the vcore voltage as high as it was when I achieved the maximum speed, or can I lower it to all that was needed to run Prime95 for +/-10 minutes at the speed I'm setting it at for stability?
Someone please let me know this so I can continue with my overclocking project.
In other words, my maximum speed is 2538mhz at 1.65v, do I set it to 221x11 (2431mhz) but keep the voltage at 1.65v, or can the voltage be lower? I originally found 221x11 stable for at least 10 minutes at 1.5v, and that would be good because I might want to still run AMD Cool'n'Quiet; which automatically sets voltage to 1.5v.
Question #2: I haven't tried using lower multipliers yet, should I? What are the advantages, other than more variability in cpu speed?
Here are the notes I took.
max 1.5v:221x11=2431 (10 minutes); 222x11 (2 minutes)
max 1.55v: 225x11:2475mhz (9 min stability) / 226x11:2486mhz (no stability)
41c
max 1.6v:227x11:2498mhz (stable 6 minutes) / 228x11:2508mhz (no stability) 42c
max 1.625v:228x11:2508mhz (9 minute stability) 52c
@1.55v=270x9=2430mhz; 275x9=2475 (44c) (5 minutes barely);
@1.6v=276x9=2484; 277x9=2493(7 minutes); 278x9=2502 (7 minutes); 279x9=2511 (10 minutes+?) (46.5c); 280x9=2520 (9 minutes\.);
@1.625v=281x9=2529 (2.5 minutes)
@1.65v=281x9=2530 (8.7 minutes); 282x9=2538 (2 minutes)
maximum CPU speed 2538mhz. (2538x0.95=2411.1)
The Athlon64 3500+ New Castle has a 130mm core which runs at 1.5v factory default. Word on guides and forums is max voltage for overclocking 130mm chips safely is 1.6-1.65v.
Rightmark CPU Info:
minimal: 4x, 0.8v
maximal: 11x, 1.55v
This third and last question is partly related to Question 2:
FOLLOWING THIS RIGHT-HERE OVERCLOCKING GUIDE, the highest CPU speed I've booted up into was 282x9 = 2538mhz (Prime95 ran for 2 minutes before blue-screen) at 1.65v. With the multiplier set to it's maximum, I could get only 228x11=2508mhz, (Prime ran for 9+ minutes before I stopped it, or it blue-screened, I can't remember, but it probably blue-screened) at 1.625v. 229x11=2519mhz, significantly lower than 282x9=2538mhz, so why doesn't it work?
So Question 3 is can anyone give me any clues on why 229x11 won't let Windows boot up and when, if at that point, attempting to go to 1.65v actually sets the vcore on the A8V Deluxe Rev.2 to like 1.77v (according to the bios hardware monitor, which scared the crap out of me and I immediately turned the HTT/FSB back to 228 and the vcore down to 1.5v and restarted). Switching to 1.65v before did not cause this glitch, when I was successfully able to OC to 282x9 = 2538mhz at 1.65v. Furthermore, I've heard of processor/motherboard combos like mine doing significantly better on air cooling with a 11x multiplier, around the 270mark. It is just that my cooling isn't good enough? The cpu temp gets to about max 47*c on full load at the top speeds.
Oh one last thing I just discovered: The memory timings on OCZ's website specify 2-2-2-5, but that crashes Memtest86 on test 2, no overclock. I have to run 2-3-2-5 instead. Motherboard vltage maxed at 2.8v, A8V Deluxe Rev.2 and OCZ Platinum PC3200 4x1024mb. Any ideas on that?
Thank you in advance for any clues you can supply.
41c
Rightmark CPU Info:
minimal: 4x, 0.8v
maximal: 11x, 1.55v
