Help need with install..
ParasiticFly
113
OK im making a totally new computer right now but im having a pretty frustating problem.
OK I can NOT get the cdrom to read the windows 2000 CD..... or the Win 98.. or the Win 95...
I have the hd as primary master and the cdrom as secondary master.
I get to
Boot CD?
I hit enter and get
CD BOOT FAIL, INSERT BOOT CD AND HIT ENTER
gah
epox 8k7a
gainward geforce 3
512 2100 DDR
herc gametheatre xp
bleh this sucks I am a total computer building newbie and its probably really obvious what im doing wrong...
ucvb6
758
have you used the Win2K CD before on another computer? my guess is that the somethings wrong with the CD...
what kind of cd-rom do you have?
bbaeyens
14
I dont want to insult your intelligence, but when you say secondary master, did you jumper the CDrom drive as "master" and connected it to the second IDE channel ? And not an IDE RAID channel ?
Are you using the orginal CD's or copies ?
gopunk
29,239
make sure the drive you put the cd in is the first device on your boot list (in the bios).
ParasiticFly
113
<< I dont want to insult your intelligence, but when you say secondary master, did you jumper the CDrom drive as &quot;master&quot; and connected it to the second IDE channel ? And not an IDE RAID channel ?
Well... what SHOULD I have done
Im using the original win 98,95 and a copy of win 2k
ParasiticFly
113
<< make sure the drive you put the cd in is the first device on your boot list (in the bios). >>
Yeah I did that
ucvb6
758
i think what bbaeyens is trying to say is, check the jumper settings on your CD-rom
ParasiticFly
113
<< i think what bbaeyens is trying to say is, check the jumper settings on your CD-rom >>
and they should be... what
bbaeyens
14
It doesnt matter, as long as you have one master per channel, and you do not use the RAID (if you have onboard RAID) for the CD rom drive
You could either do:
Harddisk master on primary IDE channel, CD rom slave on primary IDE channel OR
harddisk master on primary IDE channel, CD rom master on secondary IDE channel
Make sure you jumpered the CD and HD correctly.. dont use &quot;CS&quot; (cable select).
Make sure you connected the IDE cable correctly (in some cases you can misinstall it, but turning it around. The red edge on the cable (pin 1) should always be at the power connector side)
ucvb6
758
here's another suggestion?
your inserting the Win2K CD after installing all the files from the 4 boot diskettes right?
Win2K boots from boot disk #1, not the CD.
but that still doesnt solve the problem of why win98 and win95 won't work. hmmm...
ParasiticFly
113
<< It doesnt matter, as long as you have one master per channel, and you do not use the RAID (if you have onboard RAID) for the CD rom drive
hdd prim master cdrom prim slave connected correctly.
damnit it always gives me this crappy error message
ParasiticFly
113
I tried another Cdrom drive.. same result.. how do I make a win 98 boot disk? damn this sux
mstudd
425
Does your BIOS detect the CD drive?
If it does, you know it must be configured to work and it must be cabled correctly.
If it won't boot direct from the CDROM, try the boot discs, if you don't have them you can download them from Windrivers.com if you look hard enough.
Pederv
1,903
Go to control panel>add/remove programs>windows setup and create disk. You may need the win98 cd.
JonnyDuke
369
OR...when pop the WIN98 CD into another computer select &quot;make boot disk&quot; from the menu window that will pop up after the CD is read. The disk it creats can be used to install WIN98 on any other machine.
