- May 20, 2010
- 6
- 0
- 0
I am using a 12v POE (power over ethernet) to power a wireless router.
I am wanting to solder on router PCB where the DC jacks connect. There is clean bead of solder on the pin connection on the bottom of the PCB and no other attachment is hooked to this power source to worry about any conflcit developing.
Once I do this, I then want to power an LCD Display/Controller which controls an internal fan. I could just run a fan directly from the DC jack pins using a 3 pin connector.
(But I want more) The kicker is.... I want to add a LCD display with a variable fan speed dial controller with sensors so I can display Heat sink heat and also measure RPM speed on fan.
I found of these devices on ebay.
They have pre built connectors going out from the unit to run a fan from the Control/Display unit and the sensors are obviously already connected.
However the power source coming in is a standard 4 pin 12v power cable just like that built in PC case. These display/control units are originally designed to go into your empty bay of a tower on a desktop system and use the standard 4pin power connection. Remember, I want to use this device and then have it drive the fan, the question is how do I power the display/controller from a 12v 2 pin DC jack connection off this router PCB. I know the router can drive an internal 3 pin fan,so the real question is how do I connect a standard 4 pin power source to it to drive the LCD display and variable fan controller?
Again, My issue is how to use the power off the internal 12v PCB to power this display controller. I searched for a pre-built 3 pin connector for power input like the fans use to power a display, but none exist.
Another question I have is what will I need to do to make sure I do not overload the 12v power source by running all these mod devices inside the router, ( ie. The router itself, the Display and the fan powered through the display wiring options.)
I am going to put a heat sink with a fan on the CPU chip for the router inside the router. And I will add heat sink to the ram chip inside to help keep heat down as well.
I am going to overclock the chip to max and by using DD-wrt third party firmware.
Any advice will be helpful.
I will be using a WRT54G Linksys wireless router.
