HELP need to know what neosporin is in chinese
Stiganator
2,492
I have a few cuts and scrapes and I want to buy some antibiotic ointment, but when I say antibiotic in chinese(kangshengsu) they bring me a cippro knockoff and when I say ointment (yaogao) they bring me these large tubes of god knows what. Anybody know of a brand or the proper name for it so I can get a little 1 oz tube of neosporin or the like?
Thanks
Eli
Super Moderator | Elite Member
8
Hmm..
Searching for China Neosporin on Google just brings up lots of sites saying to bring it with you if you're traveling there.
This makes me think you're SOL. ;)
yhelothar
18,409
39
neosporin isn't very good anyways.
You should get some betadine. All hospitals use it as an antibiotic ointment.
DanTMWTMP
15,908
19
Apply Tiger Balm!!
k anyways, in all serouisness, this is what I do:
Get rubbing alcohol, rub area w/ rubbing alcohol and sterile cloth. Then, I proceed to lick it to cover it in my saliva.
Rinse repeat throughout the day.
And besides, you guys DO NOT KNOW rubbing alcohol PAIN until you've applied it to your butthole area.
The first time I tried it, I was on the floor, incapacitated with pain, followed by extreme relief of the pain going away. It's a real rush. (of course, i had a cut via..umm, well, umm, well..anyways, had to disinfect down there. AND NO, I DO NOT APPLY SALIVA THERE. ONLY ON WOUNDS LIKE ON THE ARM.)
Eli
8
Originally posted by: DanTMWTMP
Apply Tiger Balm!!
Umm...
So, you apply rubbing alcohol to your penis.. now we've learned you apply it to your anus.
Is there anything else you would like to share with us? :shocked:
yhelothar
18,409
39
you don't put rubbing alcohol on your wounds. That hurts like a biatch. There are better disinfectants out there that doesn't hurt. kthnxgg.
neutralizer
11,552
Apply Tiger Balm!!
:Q um applying saliva down there would be like... uh... :Q
Aarondeep
1,115
look for something with a chemical name mupirocin. It is the generic term for a antibiotic cream/ointment
Eli
8
That isn't what Neosporin contains; Neosporin is neomycin, polymyxin B and bacitracin zinc.
neutralizer
11,552
Yup.
MedicBob
4,151
Bacitracin will work. Just clean water with soap should protect just as well as long as you covr it with a sterile dressing.
kirkaptain
494
BandAid has a cream for nicks and cuts, I picked some up while I was in Beijing several years back. It is basically Neosporin. Unfortunatly, I no longer have that tube. HERE is a scan of the box of Chinese bandaids I do have.
I have no idea how to pronounce it.
I really hope this helps. Otherwise, MaoTai will kill anything.
Aarondeep
1,115
It's not the same thing, but it has essentially the same function as neosporin.
kogase
5,213
Apply Tiger Balm!!
Does it match with that "other" rubbing alcohol pain?
