Help. Need to build a case for this. What material to use?
yeah another thread because I don't build custom cases and
I know several people here do or have experience doing it.
so I'm just tryin to find out good materials to use.
thx.
Man, thats almost perfect! You did that much of it yourself? I am very impressed.
Now, all you need to do is find a good case. By case I don't mean computer case, I mean something about breifcase-sized, except rigid and wider. Then, put that in there, make a cutout for the monitor, make keyboard/mouse/speakers/LAN either integrated or easily attachable, and you will have the perfect LANbox.
Heh, I'm putting my next top-end system in this amazing case I found in my basement. Its a wee bit bigger than a standard ATX case, which will allow me to have a 17/1" Laptop monitor slide in on rails, slide out and tilt when in use. With fans in the right places, I can probably put ~2.5 ghx and a 9800 in there. The case is so perect I almost cried when I saw it.
