Help!! Need some networking advice
Arkitech
8,356
4
I have a Win98 machine with 2 Nic cards (both are D-Link cards) one is attached to a 3com DSL modem and the other is attached to a 5 port hub. My 2nd machine is also Win98 with a Dlink card that is attached to a hub. My question is, is it possible to have internet access between both machines and also have the ability yo netwoth both PC's.
Thanks for any help or suggestions
SaturnX
3,415
Yes you can share net access and files/resources etc between the computers. Since you're using Win98, it has Internet Connection Sharing (ICS) (though I'm not sure if it only came with 98SE) Well once you have your computers networks to share files etc.. simply run ICS and then follow the instructions and you're on your way.
--Mark
Arkitech
8,356
4
Is it possible to have 2 Nic cards in the same PC with different IP addresses?
Elledan
Banned
Jul 24, 2000
8,880
<< Is it possible to have 2 Nic cards in the same PC with different IP addresses? >>
Yes, this is possible.
For sharing the internet access I recommend using Sygate:
www.sybergen.com
JimMc
Go here PracticallyNetworked . Everything you need to know. If you have 98SE, you already have ICS software, otherwise you'll need Sygate, something similar, or a router.
dszd0g
1,226
Under some operating systems (i.e. Linux) it is even possible for the same NIC to have more than one IP address which is called IP aliasing. This can be useful if you have multiple IP addresses assigned from your ISP and you have more computers than that on your LAN and use a private network (i.e. 10.x.x.x).
Having multiple network cards in the same machine is called multi-homing. One has to be careful if one combines routers and multiple multi-homed machines in order to avoid creating routing loops. Some OSes turn on forwarding by default, others do not.
Arkitech, also if it starts annoying you that you have to have the multi-homed machine on for the second machine to access the net you can look into a hardware solution. Netgear makes a good cable/DSL router RT311 and one with a 4 port switch to make a router/switch the RT314. Linksys also makes the BEFSR router(/switch(/USB)) series of products that have won many awards. I'm personally a Netgear person though. To each their own. Cisco and others also makes very expensive solutions to the issue. :)
