I tried looking on http://www.exrx.net/, but either I missed the exercise or they don't have it. Anyone know the best way to do dumbell deadlifts
Originally posted by: cHeeZeFacTory
sorry..geeks don't work out 🙂
Originally posted by: mrchan
Why would you deadlift with dumbells?
Originally posted by: ArmenK
This may help.
Stiff-Legged Dumbbell Deadlift
Exercise Data
Main Muscle Worked: Lower Back
Other Muscles Worked: Hamstrings
Equipment: Dumbbell
Mechanics Type: Compound
Tips: Bend at your waist with your head up, back straight and knees nearly locked. Hold dumbbells at arm's length with palms facing in. Straighten up while holding the dumbbells at arm's length. Lower back down to the floor. This can be a dangerous exercise if not done correctly or done with weights that are too heavy. Can also be done standing on a bench or box or with a barbell.
Originally posted by: xXped0thugXx
http://www.exrx.net/WeightExercises/Hamstrings/DBStrBackStrLegDeadlift.html
That is not the same thing. Unless of course he wants to work his hams and not his back.
Originally posted by: Spamela
i've done them as a variation on regular DL's.
put the DB's just outside your ankles or slightly ahead.
keep your back as straight as possible & keep the
DB's close to your body during both the concentric &
eccentric phases of the lift.
the only problem i had was that the DB's
weren't very heavy (150 lbs each) & i had to do a lot of reps,
which made hand perspiration an issue - chalk
or straps took care of that.
