Help! Need partition program that works with Raid card!
Kwad Guy
I have two 18.2 GB hard drives raided as RAID 0 on an
AMI MegaRaid 428 (Enterprise 1200) Raid card. I installed
Windows 2000 on this card, and the partitioning routine
on the Win2000 install CD saw the Raided discs correctly.
HOWEVER, I try to use Partition Magic 6, it sees the
Raided drives as a single drive of around 8Gb. Same
thing happens in Win98 if I try to use FDISK.
Is there a way to get Partition Magic to work properly
with this raid setup? Or is there another program
(Partition Commander, for example) that does work
with it?
Kwad
Just partition with Win2K. You can change the filesystems later. And note, you don't have to letter every partition in Win2K.
-SUO
