- Apr 28, 2001
- 272
- 0
- 0
Hey guys, here's my situation. I have 2 systems:
1) Athlon XP 1900+ on a Shuttle MN31N (nForce2) w/256MB PC2100 DDR
2) Sempron 2200+ on ECS 741GX-M w/640MB PC2700 DDR
The 2nd one was given to me by my sister because it has this issue where you have to press the power button twice for the machine to boot up (once powers it up, but you need to press it again to get the monitor to come on and proceed to boot), and then it lags like hell and usually crashes eventually. I suspect this problem is the POS ECS mobo, which I read may have known issues w/WinXP, or something to that effect (probably why it was so damn cheap... the machine came w/Lindows), though the power issue would seem independent of OS.
ANYway, my friend just hooked me up with 2GB of PC2100 DDR, which I was thrilled about since my Athlon is running painfully slow due to lack or RAM, BUT it's ECC and did not work when I popped it in the Shuttle (it shouldn't work, right?).
So I'm thinking I'm going to buy a new ECC compatible motherboard for the Athlon and use the Shuttle with the Sempron. Will this work? Does the MN31N support PC2700 (333 FSB) and the Sempron 2200+ (is it Socket A?), and can an Athlon XP run on ECC RAM?
If this is possible please suggest a CHEAP ECC compatible Socket A mobo (266FSB) for my Athlon XP, preferrably w/onboard video so I don't have to buy a new vidcard too. THANKS!!!
