HELP! Need info on sound card!
I just purchased a Creative Sound Blaster Audigy2 ZS Platinum Pro on ebay (used).
There is supposed to be a power adapter cable that goes from a 4 pin molex to a floppy drive connector. Looks like a standard floppy connector. The adapter is not included and I want to make sure that if I hook up a standard floppy drive power connector, that I will not fry the board.
I connected a standard floppy power connector from a disconnected power suppy. It fits perfect. The website and user manual is no help.
Does anyone know if I can plug a standard floppy connector from my power supply?
Thank you!
