Help. Need info on Radeon LE
need4spd
1,369
Hi
I have a Radeon Le card that i just installed in my older 1000MHz AMD machine. Bummer... it did not come with driver (I run win 98 on this machine)
Please help ...
need driver and any info on installation. It should be easy.
Any advice
WarSong
1,147
you probably want to get the rage3d tweak while you are there. with it you can enable hyperZ and overclock it to stock radeon ddr speeds.
