Help!!! Need help setting up a remote Seti Queue!!!
Tarca
This seems funny but after running Seti for 2 years I am trying to set up a remote Seti Queue for the first time and seem to be having trouble...
I can view the seti queue but I can not transfer any units to it from my home PCs...
Everythng looks correct any ideas.
I need to do this from the pc that the queue is on correct?
I can not change this remotely through the queue correct?
I'll change that on Monday thanks for the help!
Yeah...the machine on which SetiQueue itself is installed. I don't think you change the subnet mask from the html pages...just whether any IP is disabled or enabled (maybe setting to disabled and then back to enabled will reset the subnet mask to 0.0.0.0?) (Assuming you have the admin username/password.)
