Help!! Need Help deciding cpu' + video cards =o)
Wizzio
Hi guys
I just needed some input on what to get..i'm running a gaming center and we currently have Duron 650's with Voodoo 3 3000's and 128 ram and all that other good stuff..i'm thinkin bout gettin
10 more computers but i'm not sure what to get..the budget is limited to about $950 max per computer so i can either get
Duron 650 with Geforce 2 MX
or
Thunderbird 800 with a Voodoo 3 3000...
any input would be nice!!
Hopefully someone will read this soon!!
Thank you all!
AngelOfDeath
1,203
Take the Duron 650 w/GF2 Mx and clock the bastards. That way you'll gain the most in price vs. performance :)
Just IMHO
AoD ;)
[EDIT]By the way 10!!! computers[/EDIT]
Wizzio
UPDATE - I doubt i'll overclock the computers because i'm not sure how stable over clocked computers will be especially since these will be on pretty much 12+ hours a day with intensive gaming use..so overclocking won't play much of a factor unless someone can tell me how to do it without much risk =o)
Thanks though!
cpars
1,709
I agree with Angel. I have both CPU's and do not see any difference in Unreal Tournament. From all that I have read I believe the geforce 2 mx is a super deal and If i had not alredy payed more$ for the geforce 2 gts would go for the MX. Getting 7358 on default bech in 3DMark 2000.
Oh and just saw your update:
you could still overclock and stay moderate and not push to the edge as most of us do. For example My Tbird 900 runs fine @1050 until i crank up UT for a few hours and it will crash the game. I can clock back to 1000 and never crashes. I ran the Duron 600 without incident @900 Vcore1.85 except when enabling AGP4X with reg hack, and overclocking vid card too high.
Whitedog
3,656
Definatly lean towards the GeForce video card... CPU's don't play as much as the Video card these days...
xtreme2k
3,078
i Agreen with the D650 + G2/MX Combo
should run fine for Quake3 even at 1024/32HQ at around 50FPS in timedemo1... which is acceptable
DONT GET VOODOO3, you WILL REGRET
i had one and it simply is too slow for anything 1024
running T800 + V3/3k on the same q3 but at 16bit gives around 40FPS in Q3 timedemo1
not very good
