I tried to use crossover cable to set up my home network between my desktop and my laptop PC. Both of my PCs run WIN98, and I set up the same network software for both of them( client for MS Networks, IPX/SPX-compatible Protocol, NetBEUI,...). NIC for desktop is Linksys LNE100TX, and laptop is Linksys Combo PCMCIA. And I already set file and printer sharing for MS client.
The problem is that each machine can only see itself in Network Neighborhood. I have checked a lot of reference, but still can't solve this problem.
Any suggestion would be appreciated. My suspect is if the crossover cable can connect desktop and labtop (different ethernet card). Because I can only use PPP dial-up to internet. My plan is to install one proxy on my desktop after network successfully set up. So I didn't assign IP to them during the network setting procedure. I don't think that will cause my problem.
Thanks.
Thanks.
