ALL:
Objective: Build a system based on P4-478-Northwood on i850 chipset.
Budget: 1500.00
Use: Mostly office work (will run Oracle DB and Oracle 9iAS) + some games (like Flight Simulator) + Video Capture. Currently have a Samsung 170MP flat panel.
I am not very familiar with overclocking but would like that option once I successfully build this.
I would also like to make this system future proof
as much as possible.
I am ordering through mwave including their aluminium case. Their site lists some options for this case but I have no idea how to order these., or do I need it? Here is what I am planning to get:
A14225MWAVE AL-4620 ALUMINUM MID TOWER (PENTIUM 4 READY) NO POWER SUPPLY
4x5.25" 2x3.5" 4x3.5"(hidden) W/ FRONT I/O CONNECTOR Detail Specs
$135.00
A03079INTEL PENTIUM 4 1.8A GHZ (BX80532PC1800D) W/512K CACHE 400FSB
478-PIN RETAILED (3 YEARS WARRANTY)$219.00
202754TURTLE BEACH SANTA CRUZ PCI (*While Supplies Last!) Detail Specs
$69.00
508663VISIONTEK XTASY 5564 64MB AGP EVERYTHING (PERSONAL CINEMA) 256BIT
(*While Supplies Last!) Detail Specs $169.00
A16290LITE ON 32X/12X/40X EIDE INTERNAL CDRW BURN PROOF W/SW (Retail)
Detail Specs $115.00
415543KINGSTON KVR800X18/256 256MB 800MHZ ECC RIMM
**FOR INTEL PENTIUM 4 SYSTEM MUST BE USED IN PAIR** Detail Specs
$105.60
289579PROMISE FASTTRAK100 TX4 PCI ULTRA-ATA/100 4-CHANNEL RAID CONTROLLER
(Retail) (*While Supplies Last!) Detail Specs$125.00
A14060SEAGATE BARRACUDA 80.0GB ST380021A UATA-100 7200RPM 8.9MS 2MB(Bare
drive) Detail Specs $162.00
A00695SONY 1.44MB FLOPPY DRIVE (Bare Drive) Detail Specs $13.50
A084003COM 56K V.90 INTERNAL PCI FAX MODEM W/VOICE MODEL #2976
(OEM)$56.00
A14766ASUS P4T-E/WOA INTEL 850 CHIPSET ULTRA ATA100 ATX FORM FACTOR
1xAGP(PRO)/5xPCI/1xCNR/4xRIMM W/O AUDIO Detail Specs (CPU TYPE:INTEL
PENTIUM 4 - 478PIN)$158.00
A12311MWAVE 400W (PENTIUM 4 READY) UL & FCC POWER SUPPLY FOR ATX CASES
Detail Specs $68.00
1282173COM 10BT/100BTX FAST ETHERLINK XL 3C905CTXM PCI W/PC & NETWORK
MANAGEMENT 1-PK (*While Supplies Last!) Detail Specs $49.00
063672SIIG INTEK 21 1394 FIREWIRE 3-PORT PCI DV PACK W/DV EDITING SOFTWARE
& CABLE (*While Supplies Last!) Detail Specs $41.00
A15020TOSHIBA SD-M1612 16X-DVD/48X-CDROM EIDE INTERNAL * 2X DVD-RAM
playback! (Bare drive) Detail Specs $69.50
Sub Total$1,660.20
$135.00
$69.00
$105.60
(OEM)$56.00
Detail Specs $68.00
Sub Total$1,660.20
