HELP! need assistance from batch file expert
Psyber
Hi,
Hope I phrase this correctly. I wanted to create a batch file that does the following. I want it to run a program that takes in a variable that is dependant on the date. For example the original code (which doesn't work) is:
call rmagic.exe -statistics_File_In=C:\webStatistics\%yy%_%mm%_%dd%-MYwebsite_Stats.dat
I need the %yy%_%mm%_%dd% part of it to output the actual date separated by underscores. I am running Windows NT if that has anything to with what approach I should use. Any help would be appreciated.
Also, kinda off-topic, any suggestions on good forums to get answers for programming questions.
Mucho Thanks in Advance,
Psyber
I don't think there is a way to do this with a simple batch file. You might want to look into:
1. 4NT (which has a much expanded batch language)
2. writing a small C program to output a small batch file, e.g.:
set dd=05
set mm=09
set yy=02
That you could then CALL from your main batch file.
3. doing the whole thing in perl. 🙂
I find the Arstechnica "Programmer's Symposium" to be very good, lots of professional programmers there.
Use VBScript/WSH. As you've probably guessed, batch files were not designed to do anything complicated.
I've gotten some help on this. I would like to keep it a simple batch file if possible.
@echo off
for /f "tokens=2-4 delims=/ " %%a in (
'date /t'
) do set yy=%%c&set mm=%%a&set dd=%%b
set yy=%yy:~2%
set currentDate=%yy%_%mm%_%dd%
That is the part that does work. This is the part that doesn't:
call C:\webStatistics\ReportMagic\rmagic.exe -statistics_File_In=C:\webStatistics\%currentDate%-MYwebsite_Stats.dat
Anyone know how to piece together a executable with attributes that stem from a variable?
Thanks!
Edit: Brain kicked in and came up with a way that didn't use a temp file
Actually, that part you think works doesn't. This is the working version of that I came up with:
@echo off
for /f "tokens=2-4 delims=/ " %%a in ('cmd /c date /t') do set yy=%%c&set mm=%%a&set dd=%%b
Copy and paste the above since there's a very critical space in there you might miss if typing.
Now you can use your original call rmagic.exe -statistics_File_In=C:\webStatistics\%yy%_%mm%_%dd%-MYwebsite_Stats.dat
BitSpit, YOU ROCK!!!
Thanks, your code works with a slight change. Final code is as follows
@echo off
for /f "tokens=2-4 delims=/ " %%a in ('cmd /c date /t') do set yy=%yy:~2%&set mm=%%a&set dd=%%b
You beat out 2 other forums I posted at. 😉
