Help! Need Advice for system configuration[ long post]
rykyc
Hi guys,
well, i posted a question on this forum a couple of days ago, and I received so much helpful info, that i've screwed up the courage to ask my decidedly newbie question. this is the first time i'm putting together a machine, and i'm totally confused with respect some of the components i should buy. Also, I'm afraid if i spend any more time researching(read: obsessing) about this, my wife will leave me and i'll lose my job, so please help! Thanks in advance for reading such a long post.
System Requirements:
Basically, at this time, the biggest reason for creating this system is to convert my old audio tapes to mp3. It seems a critical component in achieving a good transfer is having a very good sound card, which is why i'd prefer a mobo without on-board sound. apart from that, the only activities are running office applications, listening to music, browsing. No games or other video intensive stuff. Also, don't want to spend more than about $650, at this time(not including moniter)
What i have decided so far:
Hard Disk : IBM 40-60 GB drive@7200rpm
Sound Card : Soundblaster Live!
CPU : Athlon 1.0-1.4 GHz, depending upon 'mobo' (i love saying that word!)
CDRW: On-lite 16x or 24x
Video Card: Any cheap one, even on board video support is fine
Need your advice about:
Mobo: cheap but good. I'm kind of leaning towards the K7S5A, but i'm not sure if that has the KT266A chipset. Please also suggest
if i should go with the KT266A, or the SiS735 or the AMD761. I know this is a loaded question, but that's precisely why i'm
stuck. I'm not planning to use SCSI or RAID, just EIDE devices. If it does have on-board sound, how easy is it to disable it. I
guess having a good number of PCI slots and USB support are also important.
CPU : that would be suitable for above Mobo.
Case: I used to think the case was the least important piece of the puzzle, but i've seen the folly of my ways in the last couple
of days.I've read really good things about the Fong Kai cases here, but are there any others that might be good and
cheap? I'd probably want at least 6 bays(cd-rw, dvd-rom, hard drive, floppy = 4 gone already). Also, it seems that the
choice of case may also depend up the mobo, due to P/S requirements.
Audio/Video Card : any feedback about my choices, and others, would be welcome.
CD-RW: your thoughts about the on-lite, or others.
I know i'm asking to be handfed here, but all advice/admonishments are most welcome.
ryky
<< Mobo: cheap but good. I'm kind of leaning towards the K7S5A, but i'm not sure if that has the KT266A chipset. Please also suggest if i should go with the KT266A, or the SiS735 or the AMD761. I know this is a loaded question, but that's precisely why i'm
stuck. I'm not planning to use SCSI or RAID, just EIDE devices. If it does have on-board sound, how easy is it to disable it. I guess having a good number of PCI slots and USB support are also important.
K7S5A is good, but KT266A is faster. Get Shuttle AK31A.
<< CPU : that would be suitable for above Mobo. >>
Go for Athlon XP 1500+. It's a solid CPU and is pretty fast in MP3 encoding.
<< Case: I used to think the case was the least important piece of the puzzle, but i've seen the folly of my ways in the last couple
cheap? I'd probably want at least 6 bays(cd-rw, dvd-rom, hard drive, floppy = 4 gone already). Also, it seems that the choice of case may also depend up the mobo, due to P/S requirements.
First a 300W p/s is fine if u go Athlon XP. I would go for Antec for the case. They're solid
<< Audio/Video Card : any feedback about my choices, and others, would be welcome. >>
Audio, go SB Audigy (Platinum maybe?). Video Card, just go for a Radeon 7200. It's got solid 2D Performance/Image Quality.
<< CD-RW: your thoughts about the on-lite, or others. >>
Dunno sorry
Well first you should read this
faq by member workin' and he is probably the best person to ask anything about audio or video conversion to digital format..
I noticed price was an important consideration of yours and you are very fortunate at this time because of the economy and drastically low PC prices right now. You can get a kick ass system for less than $600 all at newegg.com delivered to you door.
Price performance best system imo:
K7S5A- $62
256 mb crucial DDR ram - $33
Radeon LE- $67
lite-on DVD - $50
lite-on Burner -$70
WD 40 gig HD- $100
MS opticla mouse $37
Athlon retail 1.2 ghz $95
Case antec 1030 $77 from ems computing?
$591 plus 28 ship from newegg.com and the case I don't know shipp price
Another option yet cheaper but nonetheless still decent:
MSI KM133A with on board video and audio- $83
128 megs pc 133 crucial -$17
lite-on Burner -$70
WD 40 gig HD- $100
442
Now if you need keyboard and mouse it will be more but don't skimp here the MS versions has the best erogononics around.
On-board sound can be disabled in a few seconds in the BIOS, it's not a problem.
$96AMD Athlon TB 1.0GHz Retail would probably be plenty for your needs. I can't see Word crawling on that...
Uhh... an Antec 1030 is kind of overkill: go for an Enlight EN-72370X3C4 ($47) if you don't care about looks. 🙂 It has four 5.25" bays (CD-RWs, DVD-ROMs, etc.) and enough 3.25" (floppy, HDD) for you.
OEM? Audigy $63
IBM 60GXP 40GB's $99, or a 60GB for 35 more.
Your CDRW is great.
What OS? 256MBs of RAM'll do fine on Win98, but for 2000/XP you'll prolly want 512.
