Help! My wheel locks broke off
Aharami
21,205
165
I was putting on my winter wheels today and one of my wheel locks broke off. The key is a little messed up too and it doesnt fit the other locks. But luckily this was the last wheel I had left and I dont care about these locks as I'd get a new set of locks anyways when I put my summers on in the spring.
How can I get this lug off? What shop can I take it to? I live in central NJ
Pics
http://pics.apartment808.com/users/aharami/IMG_0005.jpg
http://pics.apartment808.com/users/aharami/IMG_0004a.jpg
http://pics.apartment808.com/users/aharami/IMG_0003.jpg
http://pics.apartment808.com/users/aharami/IMG_0002.jpg
Minjin
2,208
Find an impact socket that will just barely fit over it. Hammer it on. Gun it off.
TitanDiddly
Guest
Dec 8, 2003
12,696
Originally posted by: Aharami
Originally posted by: drnickriviera
Any decent shop should have a welder. Just weld a nut to it.
I dont want to risk damaging the wheel though
Get a welder who is good at GTAW. What is the material? Wheel is Aluminum, I assume, but is the lock steel?
Antisocial Virge
6,578
The two ways I have seen it done. Do as stated above and get a welder weld a nut on, any good welder can do it without hurting the rim. The other one is a long rod and a sledgehammer to snap the bolt, that would damage the rim.
thedarkwolf
9,034
127
I just hammer a socket on to them. If you take it too a shop thats probably what they will do.
jaybert
3,523
goto a shop, they have tools which take off broken wheel locks. I believe its kinda like the gator grip, they just stick it it on an impact wrench, and blow the lug nut off. I messed up a couple of mcgard lugnuts a few years ago, just took it to goodyear, and they had em removed in a few minutes.
Aharami
21,205
165
awesome. there is a goodyear store around here!
jaybert
3,523
i assume this will work for yours too...but my damage wasnt as bad as yours. I stripped the key on the inside, but the outside was still intact. It should still work though...worth a shot
fbrdphreak
17,555
This should work fine. Or get a cheap socket that is slightly larger than the lock, hammer it on, and use a breaker bar to try and remove it.
