help my washer suddenly stopped
z0mb13
it was in the middle of a cycle... suddennly it just stopped. I took all my laundry out and I want the water to drain
its a whirlpool
any clues?
i've used a few broken washing machines in my time... i've just tried changing the cycle a few times... try telling it to spin... sometimes that'll force it to drain.
you any good with a DMM?
any noises? vibration? can you hear any relays clicking?
to just drain the water UNPLUG it and THEN turn the water pump by hand.
stuffed inside somewhere there will be a schematic, scan or post a picture of it
Originally posted by: Megatomic
Try turning it off then putting it back in the same place it was in the cycle and see if that "wakes it up".
did that, and doesnt work..
stupid washeR!!
See if the breaker that feeds the washer is in the trip free position.
Then move on to finding a blown fuse. I've had fuses go on them before.
