Help, my temps have shot way up!
Quad
1,222
1ghz tbird, asus a7v133, alpha pal6035 with ystech fan, artic silver applied.
when i built this comp in march, my idle temp was 42c with case off, 45c with case on. now that summer has come by, and i don't have air conditioning, it has gotten really got and humid. and my idle temp is now 54C! why has it shot up so much? should i be worried?
btw, i have 1 exhaust fan
AMDPwred
3,593
FANS FANS and more FANS:)
I didn't know that going to summer would change the temps that much. Just try and add more fans. See if that would help.
Quad
1,222
ok
but how come the weather outside has affected my temps so much?
OCnMan
185
<< how come the weather outside has affected my temps so much? >>
Uh, Dude, doesn't the hot weather make you feel hotter too? If your computer starts out with hotter air to cool it, it will run hotter.
OCnMan
The_Lurker
1,366
OCnMan
he's right yano? My temps for my mobo shot from 25 - 28 degrees, no way to get it back down cause the air temp is much higher. Just an example.
bjc112
11,460
if you don;t have A/C that has to be the answer.. that keeps the house temp about 10-15 warmer than in the winter! (well somewhere around there)
AMDPwred
3,593
<< Check your thermal compound, it may have dried out? >>
Good point. Wouldn't hurt to check that real quick.
LASHER555ZX
21
Quad put a DELTA on that ALPHA if u can stand the whine and if not get A/C. More fans too. Summer is only going to bring &quot;HEAT&quot;.
DollarBill
344
Sounds like you need a good &quot;COOL&quot; case (Antec SX 830) with a minimum of 4 fans running. Two in, &amp; 2 out. It comes with 2 fans installed.
MCS
2,519
A Delta 37CFM fan will get you back under 50C I am sure, it's just a question of noise. The fan actually sounds louder on some heatsinks than others. When I tried one on my Taisol it was UNBARABLE but now I have it on a Thermalright SK6 and its not even half as loud - no joke. The SK6 must stop it vibrating as much.
