Started when I was minimizing my MSMedia player and don't see the little Media bar in the task bar. So I was disable and re-enable it and it showed up wrongly.. moving it around and now my taskbar is gone.
Pic.
Pic2 (just to show MSword is running but not display b/c the taskbar is gone.)
As you can see, there is a little bar on the right. If I move the "MyToolbar" into it then I will be able to drag that bar out and see the "Start" button. But you see strangly when I press the Window key on the keyboard it pop up the menu on the left. Why would it pop on the left if the bar is suppositly on the right. I can't drag it our or anything.
Things I have tried:
1) Redo enable/disable MSMedia
2) Drag the bar out
3) Hide/unhide the bar
4) Dis/Enable verious tool bars (It will show up the tool bar but still no task bar)
5) Tried moving the bar on each corner (only able to move if there is a toolbar enable in there).
6) Restart
7) Go into Task manager > Kill Explorer, then re-run explorer
8) Switch on/off the auto hide
9) Search online (all I found are tricks about hidden taskbar, I've tried them too just for the hel of it)
This is all I can remember that I've tried.
HELP!!!
Only way I can switch between programs now is Alt+Tab
Pic.
2) Drag the bar out
6) Restart
HELP!!!
