OK, so I had an SATA RAID10 setup using 4 200GB drives in NVRAID on my MSI K8N Neo2 Platinum.
After a crash, it refused to go past the stage where it says "Detecting array..." during post.
Tried unplugging and re-plugging cables in case something was loose, this worked ONCE, briefly before another crash, never got it to work again.
Experimenting with disconnecting drives to get past this point, I found if I disconnected the drive that was on SATA1, it would at least get past DETECTING the array, but tell me there was an error. So I am now running on the mirror (SATA3 and SATA4). If I enable RAID on SATA1 in the BIOS, it will not get past the "Detecting array" stage during boot again. If I turn the SATA1 & 2 channels on but do NOT enable RAID on them, windows crashes early in the boot process (I think this messes up the drive letters to C: is no longer C: causing problems).
How do I get up and running with the first 2 drives visible to NVRAID again so I can re-upgrade the array from RAID 0 to RAID10?
