help! my pc keeps on freezing
pilmania
my computer has been acting up since last month. it sometimes freezes when i play warcraft3 and yesterday for the first time, it froze when i was just surfing theweb. however, if i leave window open, it doesn't seem to happen. i thought it might have something to do with temp, so i let the asus probe to log the temp so when it freezes again, i can restart the computer and check the temp. it was 68 degrees (cpu) when the comp got frozen. the temp stays 62 degrees when the window is left open.
I did memtest, no errors found, ran dual prime95, no errors for 9 hours, put the videocard under load using ati tool but it also seems fine with the gpu temp staying under 65 degrees and cpu temp staying under 62 degrees and checked the hdd with all the test option available on seagate hdd diagnosis tool and no serious errors were found except for file structure error (it said it can be fixed by using windows scandisk but scandisk didn't detect any problems) which led me to format and reinstall the windows. All the test was done with window closed.
What could be the cause? Could it be my psu (modstream 450W)? I noticed that under load, the 12V rail drops to as low as 11.65V and the back of the psu gets pretty hot.
oh BTW, here's my setup:
P4 660 3.6GHz
Asus P5AD2-E Premium
Samsung PC4300 DDR2 512MB X 2
ATI Radeon X800 Pro
Seagate 7200.7 200GB S-ATA 7200RPM
Fujitsu 60GB S-ATA 5400RPM 2.5" HDD
Pioneer 108 DVDRW
OCZ Modstream 450W
Nothing is overclocked.
